98 warrior with 11.5 to 1 piston... need help with gearing and jets?
Old May 29, 2008 | 12:03 PM
thor151's Avatar
Default 98 warrior with 11.5 to 1 piston... need help with gearing and jets?
I have a 98 warrior.
I need to redo my chains and sprockets so i want to find out the best combo. I have a 11.5 to 1 piston and a f&m pipe. I would like to know what size jets I need and what type of gearing I need for 22 inch mud tires....... I have dropped 4 teeth in the back but feel that is way too much. Should I go the other way from stock? I run 25 inch tires now but I want to get a set of 22 inch bear claws.
Any ideas?? please help!!
Old May 29, 2008 | 12:15 PM
Honeyduck96's Avatar
Default 11.5 to 1 piston... need help with gearing and jets? i was beat by a stock raptor 350
Might want to let them know what you're riding....
Old May 29, 2008 | 12:58 PM
thor151's Avatar
thanks!!
Old May 29, 2008 | 02:17 PM
Dirt Girl's Avatar
Thor... I beat you because the Raptor 350 is so awesome compared to the Warriors.
[img]i/expressions/face-icon-small-tongue.gif[/img]
Old May 29, 2008 | 02:44 PM
Raptor450's Avatar
150 Main jet would be a good starting point for your jets. If I were you I would keep the stock rear tooth # sprocket (40 I think) and use either the stock 13 front sprocket or go up to a 14 tooth with the 22" rears. With the 25" rear tires you may need a 12 tooth front sprocket. It's cheaper to change out the front sprocket than the rear.
Old May 29, 2008 | 05:27 PM
pmcc37's Avatar
yeah with 22's i'd proabably leave the gearing stock. as far as jetting, 150 main worked graet on mine, on striaght out runs, but when i got to riding it and lugging it, it started running a lil rich/flooding out, so i'm going with a 148 when i get the time...
Old May 30, 2008 | 04:04 PM
Dirt Girl's Avatar
So if Thor puts the stock gearing back on his Warrior with the 22's, what should I change on my Raptor 350 so I can still beat him?
The stock rear tires are 20's, but I am thinking about going with 21 or 22's to give me some more ground clearance. (Gets stuck in the mud too easy). Everything else on the bike is stock except for a K&N air filter. I don't want to change the exhaust but am open to changing the gearing if that would help me beat him. [img]i/expressions/face-icon-small-happy.gif[/img]
Old May 30, 2008 | 04:10 PM
91Warrior357's Avatar
i punished somebody who had a rappy 350 wit no lid and baffle out and i didnt even hit 6th gear until right at finish line...lol, it was on a shutdown concrete road and i did like a 6 foot burn out in first and like a 3ft in second and i think i member it lifting a little on take off...lol
Old May 30, 2008 | 04:13 PM
Dirt Girl's Avatar
No offense Warrior, but with all those mods you have no excuse not to beat a stock raptor 350.
Old May 30, 2008 | 04:22 PM
yea i know minus my exhaust...lol i heard there worse than stock pipes just louder...plus rappy has better exhaust,carb,lighter and diff size tires, but yea i know im jus saying the guy u beat isnt stock either...and my piston is a 10.25.1 his is an 11.5, figured maybe he had other things along with it that arent listed
