warrior stroker piston damage question?
Old Jun 2, 2008 | 06:28 PM
dukeduster's Avatar
Default warrior stroker piston damage question?
Her is some pics of my piston that i took out of my warrior cause of some piston slap and recently smoking. Is this from excessive heat and excessive slap from a oversized bore? Would I be better off running a oil cooler? any suggestion to help me put this thing back together?
Melted ring land??
Top of piston worn down
Old Jun 2, 2008 | 06:39 PM
91Warrior357's Avatar
yea you need to get the big bear oil cooler they like to run hot...
Old Jun 2, 2008 | 11:51 PM
Doctorturbo's Avatar
GOT BOOST!
Looks like a lean scuff to me. What did the plug look like?
Old Jun 3, 2008 | 01:11 AM
dukeduster's Avatar
yes sir it was white which I am pretty sure means lean which also means more heat right?
Old Jun 3, 2008 | 02:29 AM
GOT BOOST!
Now I'm more sure than ever. Look at the picture in my profile. Look familiar? This is with a blower so it really cooked the piston.
Was it popping on top end?
Old Jun 3, 2008 | 01:40 PM
dukeduster's Avatar
Ok, It started to ping after riding it hard. I ordered a new cylinder and piston. I am also gonna re jet the card to run a lot richer. How do I rig up the big bear oil cooler on my warrior???
Old Jun 3, 2008 | 02:42 PM
your best bet in finding out exactly how to do is go to yfm350central.com and talk to them i think they have a sticky on it to take you through the steps, or contact recon99 on this site i think he did it to his warrior he had, but its best to actually look at it that way then me telling you, but i think you bolt the cooler up near you ign. coil and then theres 2 lines that tap into your right side case if im correct.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Reactant
Jul 27, 2015 07:45 PM
