1998 WARIOR 350 RUNNING AND STARTING PROBLEMS
#21
alright so heres the thing... i worked on it today.. fixed the es problem it was the reverse sensor... it starts upp and runs fine when its on choke when i take it off choke it pops sputters and dies....does that mean i need my carb rebuit?now whenever i put it into reverse.. itll stall i tried unplugging the green wire off the reverse gear but it shut down the whole bike.. so whats going on any ideas??
#22
go to bikebandit.com , and you need to go through your carb something isnt right, as far as the reverse sensor i dont know anything bout those because mine never used one
#23
since it wont idle on no choke and run fine on choke.. what does that mean? i cleaned the barb.. does that make it outta wack? does it need adjustment? or could the motor me off timing.. cause when i take it off choke it pops spits and stalls.....
