2001 warrior starting problem
Old Jun 7, 2008 | 03:52 PM
ftwflh's Avatar
Default 2001 warrior starting problem
I have a problem with no fire to the plug.Has new plug.Tested the orange wire from the CDI to the coil and no volts.Is there a safty switch some where that could be bad.
I had to cut the brake switch wires at the clutch lever to get it to run last winter.Now the starter turn over but wont fire up even on strating fluid.
HELP PLEASE
Old Jun 7, 2008 | 04:25 PM
91Warrior357's Avatar
you try testing your stator? im not sure if the cdi tells the coil to fire or if the stator does....cant remember, theres a better chance your stator would go bad before a cdi thats not very common...make sure the boot on your ign. coil isnt messed up.
Old Jun 7, 2008 | 09:43 PM
ftwflh's Avatar
Thanks ,I will try checking that in the morning.Going to try checking all the conections first.The last time it was running I had to have a charger it to get it to start.So it could well be a stator.My Clymer manual should tell you to test the stator.
Old Jun 8, 2008 | 11:30 PM
ftwflh's Avatar
UPDATE:I checked both relays and they were good.Still now power to the coil.Checked CDI have power going in but no power coming out on the orange wire going to the coil.Dose anyone think like I do......CDI is bad?
Old Jun 8, 2008 | 11:47 PM
man...i dont know...you got a manual? they might tell if your supposed to get power out of that wire cuz im not sure...so your stator was putting out sufficient Ohms? if your cdi is poop id go on ebay and get one theres a few on there for cheap
Old Jun 9, 2008 | 07:57 AM
ftwflh's Avatar
I am leaning towards the CDI.From the looks of the manual the fire to the coil comes from the CDI.The Stator looks to be on another circut.I Think I will get a ProComp CDI off Ebay and go from there.
Thanks for the help.
Old Jun 9, 2008 | 11:53 PM
Octane2079's Avatar
I had a weak to no spark condition and it was my stator. The repair manual basically states that if everything else works it must be the cdi because there is no way to actually test it.
Old Jun 10, 2008 | 02:46 AM
thats kinda what i was thinkin cdi usually doesnt go bad the stator is crapy tho buy a rickys stator and never worry bout it again
njrider64
Jul 4, 2017 01:40 AM
Big600twin
14
Jun 16, 2015 09:30 AM
Jbird4681
Jun 9, 2015 01:59 AM
generalpops
Jun 5, 2015 08:23 PM
1000gade
May 27, 2015 12:37 PM
