What a arms fit??
Well I bought a wrecked 87 or 88 warrior. Bought a new frame from a 01 warrior and I went to put my a arms on and they don't fit! Now All I need to know is what year a arms fit a 01 warrior frame? Also can I use my stock spindles? I hope so those should be the same right?
Arms from '90-04 will fit the '01 frame. Be ready for more surprises like this because that is not the only thing that was changed after '89. For the most part, everything should fit.
Yeah I know they changed the headlights and front fenders, that shouldn't be a big deal. They also changed the swingarm and the way the axle carrier bolts to the swingarm, but as long as you use the whole '87 swingarm assembly and it bolts up to the frame you should be fine. You can't use a '87-89 carrier on a '90-up swingarm.
