Beartracker carb. question - running rich?
Old Jul 16, 2008 | 03:25 PM
xbassman's Avatar
Default Beartracker carb. question - running rich?
Tried to help my neighbor out w/his early 2000 250 Bear Tracker. Backfired when he tried to start it/hard and mostly impossible to start. I/we removed the carb. dissasembled it and soaked in my super carb cleaner, blew out all the ports, etc. Now, it starts right up, but is running rich as I see black smoke fm exhaust and notice plug is sooty. I must not know the needle or jet adjustment and need some help. Outside the carb I can adjust the idle and another adjustment in front of the bowl. Is there a pre-setting on any jets "inside" the bowl? Sure could use some help here. Another thing I noticed and had him order was the rubber connector fm the carb to the engine...pretty bad shape and thought it might be sucking air?
Old Jul 17, 2008 | 12:11 AM
warhorse20000's Avatar
If it was Sucking in AIR it Would Over-Rev.
My guss is When you Blow out the Carb , Thier Must have been a Small rubber in the Needle Seat and That Had Gone with it . Or The Rubber is Missing off the End of the Needle.
Needle & Seat is the Little pump Part In Most Carbs.
Or You have Bent the Float Prong where the Needle Spring Go`s.
UP is Rich Down is Lean. As the With the Float you can change the Fuel Consumption.
Now i wouldent know the settings of your Mixture , as i have not one of them bikes.
But default on most Apps , is : 1+ 1/4 turn on low , 1 +1/2 on High and if a Air Jet 3/4 turn out. And it should run. than Adjust from thier.
SOLOLUCKY
Oct 4, 2024 09:09 PM
green giant
Jul 13, 2017 12:07 PM
scaldwellk
Jun 19, 2015 05:08 PM
robj
Jun 15, 2015 08:45 PM
Smokinthebear
May 7, 2000 08:01 PM
