Yamaha warrior chain slack help
Old Jul 25, 2008 | 02:46 PM
laxattack99's Avatar
Default Yamaha warrior chain slack help
I have a 1987 yamaha warrior 350 and it runs great. The only thing is that the chain is definitely too loose. How do i determine the right amount of slack it's supposed to have. And i know it's too loose because i was riding the other day and it just popped right off and got wedged in the axle.
Old Jul 26, 2008 | 10:26 AM
embler's Avatar
it helps to have another person with you when you tighten it up. get them to sit on it as you tighten it. it helps if they are about the same size as you. if you don't have someone to help, a few bags of concrete on the seat will work also. I tighten mine up until I have between 1/2 to 3/4 inch of slack.
Old Jul 26, 2008 | 12:00 PM
QWODER's Avatar
I would tighten it before it comes off and wraps around the front sprocket.If it does this it might break the case of your motor and you dont want that.
Old Jul 26, 2008 | 06:11 PM
91Warrior357's Avatar
yep and you dont want that, mine had the side of the cases broke enough to where it leaked oil everywhere and it sucked, luckily my dads an experienced welder and he repaired it, but thats a pretty common thing for warriors to break those off so id adust asap b4 u ride again its fairly simple
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
