05 Grizzly 660-no high spead
Old Aug 14, 2008 | 02:57 PM
Procount's Avatar
Default 05 Grizzly 660-no high spead
660 will not go to high speed performance. removed all to the clutch and cleaned.
belt look fine. not sure if i should go into clutch or not. Will a worn v-belt cause the motor to drag at high speed, over say 10 mph?
Old Aug 14, 2008 | 04:20 PM
HeftyLefty's Avatar
Check carb and gas tank vent tubes and make sure they aren't kinked or clogged.
Drain carb float bowl, could have water in it.
Try fresh gas. Add SeaFoam.
Check primary jet in carb, could be clogged.
Change fuel tank filter and clean fuel pickup screen in tank, it could be clogged.
Worn belt won't cause engine to bog, worn belt will slip and cause engine to rev up but quad will move slow.
Old Aug 14, 2008 | 04:26 PM
Procount's Avatar
thanks i'll try that, it was in deep water. although it idles and cranks great
Old Aug 14, 2008 | 09:48 PM
ATV_MAN's Avatar
Does it sound like the engine is dying? or does it sound strong and just wont go anywhere?, if the engine is dying...Open the carb up again, take everything out that you can, submerge the carb body in carb cleaner for an hour, take it out, blow out all the holes with compressed air, blow out all the jets, re-assemble. Drain the gas tank(even take it off and tip it upside down), re-fill then try to run. Make sure all electrical connections are water free, and tight, especially the spark plug boot.
Old Aug 14, 2008 | 10:06 PM
HeftyLefty's Avatar
Procount, since you said it was in deep water check the exhaust pipe, especially if you have a custom slip on pipe. It could be that the fiberglass packing is sopping wet and stopping up the exhaust.
If that's the case, repack the pipe and snorkle it, if running deep or mud. If factory pipe, stand the quad straight up to drain out the water, and snorkle it.
Old Aug 14, 2008 | 11:13 PM
Procount's Avatar
guys, it's like its in 1st gear.. has plenty of power. like running a vechicle in 1st gear. no top end
Old Aug 15, 2008 | 02:41 AM
HeftyLefty's Avatar
So you are saying it runs great in Low, but you can't move the shift lever to High?. Or, are you saying that you can shift to High, but the engine bogs down with no power?.
Please be more specific.
Old Aug 15, 2008 | 10:19 AM
bprfwarrior's Avatar
yea we had the same problem on my dads old griz. check the jets on ours it turned out that it vibrated so much it actually made the jest oval shaped.or the 660s needed valve adjustments alot try that.
Old Aug 15, 2008 | 04:33 PM
Procount's Avatar
thanks guys, think i've found the prob. took an old man in a wheel chair about 30 secs. to tell me. primary sheeve needs cleaning. I had removed it but didn't disasemble. I'll let you know if it works
Old Aug 15, 2008 | 11:01 PM
Procount's Avatar
fixed, the primary sleeve needed cleaning. preciate all your help
hp
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
