yamaha raptor top speed and hp
No2Stroke,
What is your needle position and how far out have you turned the air screws? You sound like you have a nice setup.. maybe one worth replicating.
Do you have any idea what kind of speed you could expect from all of the same mods, but with the stock pipe with the baffle pulled?
Thanks again!
Thanks again!
I believe that would be a 4th gear dyno pull which is what almost all dyno operators use to get hp. figures. I used this formula and came up with this.
336 X Rear gear ratio X MPH
______________________________= RPM
Tire diameter
Rear gear ratio is figured by taking 4th gear ratio which is 1.047 X the Secondary reduction ratio which is 3.076 X the Primary reduction ratio which is 2.088. This puts the overall gear ratio at 6.72.
336 X 6.72 X 53
_______________ = 5983RPM
20"
6000RPM is where peak hp. has been shown to be so this would put it about right for the figures you've shown.
Using the same formula for the 77.8mph would put this at 8783.3RPM or right before the rev limiter which is where most dyno operators rev the engine to, which would account for the low hp. figure since the engine doesnt make much power beyond the 6000rpm mark.
Top speed cant be accurately measured on the dyno since it is at the rev-limiter and most bikes cant pull to the rev-limiter in the a "real" world situation.(In the upper gears of course)
If it was a 5th gear run that would put peak hp. at around 5100rpm and I think peak hp. occurs a little higher than that. Check with the dyno operator next time you see him and see if this is correct. I would like to know.
Tire diameter
336 X 6.72 X 53
20"
#15
#17
Sorry Digs I thought you were referring to the equations.hehe.
But yes you are correct the peak rpm and horsepower are measured at 4th gear.
When my dealer measures top speed thats when 5th or 6th gear come in play, usually horsepower drops considerably. There has been a case were a modded banshee pulled horsepower up in five gear but dropped shortly after it revved out.
Note the raptor reading I gave, at the top speed the horsepower rating was reduced from "38" to 18.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
SCRAMDADDY400
#18
I have yet to mess with my needle or air screw or clip position.I may need to fool with it a little, but it seems to be running pretty well.Id hate to dig into those 2 carbs again just to make it run worse
Its kinda hard to say what your Bike will run with the stock pipe because the addition of a aftermarket pipe would require bigger jets, however if you have a good intake system on it and a free flowing air filter i dont see why it shouldnt run close to 79 or so.On another level, i installed a 14 tooth sprocket when it was bone stock and it slowed down, but after the Pipe, jetting, and air filter, it pulls it really good, besides, it is hard to keep the front down with the 13 tooth and a aftermarket pipe.
juanmortiz92
07-21-2015 04:10 PM
