Is this jetting right?
Old Sep 8, 2008 | 11:48 AM
MyHatetredBleeds's Avatar
Default Is this jetting right?
Its not really backfiring, It runs great at top end. But it has a low end bog. Theres a few areas where i ride that theres houses, they gave me permission to cut across their yard as long as i dont cause any damage.
When i ride at low rpms at a creep so i dont rip up their grass. It runs like crap. bogs bad. kinda coughs and chokes. but once you get past about 1/4 throuttle it runs great.
Old Sep 8, 2008 | 01:16 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Still sounds like it's rich to me. Id adjust that idle screw back down 1/4 turn at a time and see if it clears up. You may want to go back to the stock pilot.
Old Sep 8, 2008 | 04:01 PM
ok thanks alot. I'll swap out the 48 for the stock 42 pilot jet. I'll let you know if theres any difference
Old Sep 8, 2008 | 04:19 PM
Koopa's Avatar
maybe 45 be a happy medium if you have one.
Old Sep 8, 2008 | 04:27 PM
  #15
no the kit i bought only came with the 48 pilot. 124,126,130,134,136,140,142,144,146,150,155,165 main jets.
001-main jet adapter.
DNO987-needle
Is there a site you can buy just the jets you would need?
Old Sep 8, 2008 | 04:40 PM
  #16
Koopa's Avatar
O your dealing with dj jets. They are measured a little different than stock. Stick the stock back in and go out about 2.5 to 3 turns out on the fuel screw and test that out.
Old Sep 8, 2008 | 04:46 PM
  #17
stick both the stock main and pilot jets back in? or just one of them. what about the needle i have it on the 4th notch, just leave it there?
Old Sep 8, 2008 | 05:09 PM
  #18
Koopa's Avatar
At this point I'd just change the pilot. Read your instructions that DJ sent. They should get you close. I was thinking that a 155 was recommended with lid on and the 165 with lid off but, don't remember for sure. Either way I'd do what they suggest. They usually get you pretty close.
Old Sep 8, 2008 | 05:27 PM
  #19
stage one with lid on, aftermarket exhaust.
needle on 3rd grove,
134main
048 pilot
mixture screw 1 turn out.
stage 2 with lid off, aftermarket exhaust.
needle on 3rd grove
150 main
048 pilot
This is what i came up with using dj book
Old Sep 8, 2008 | 06:05 PM
  #20
Koopa's Avatar
Holy monkey and you got a dj165 in there with lid on?? That may be a prob although wouldn't cause low speed issues.
