need a torque spec
Old Sep 13, 2008 | 10:22 AM
skj283's Avatar
Default need a torque spec
anyone wanna hook me up with the spec on the nut that holds the primary sheave on. sent it off to hauck and getting ready to get it back. i think it would pay to torque it instead of just guessing. thanks
Old Sep 13, 2008 | 04:44 PM
thewolverine450's Avatar
72 ft.lb on the 22mm nuts and 7.2 ft.lb on all the small bolts. This comes right out of the manual
Old Sep 13, 2008 | 04:52 PM
skj283's Avatar
thank ya sir
Old Sep 13, 2008 | 10:52 PM
No prblem. I will help if I can. Let me know how hard it was to pull the sheave out I will be pulling mine tomorrow
Old Sep 14, 2008 | 09:27 AM
2wolvies's Avatar
pulling the sheave is real easy. it should only take you about half hour even easier if you have impact gun for 22m nut are you getting hauck clutch work done ? the bottom end feels much better after i havent ben able to get a new top end speed run on mine with the work but it should be better as well
Old Sep 14, 2008 | 10:20 AM
miassmaro98's Avatar
what did they charge you?
Old Sep 14, 2008 | 12:08 PM
I will be doing the Hauck machinework mod. Easyiest cheapest power mod.
Old Sep 14, 2008 | 07:40 PM
skj283's Avatar
ya it was a snap to pull it. i went ahead and pulled the floorboard to open up some space in reality i dont think you can get the sheave off without removing the floor board though. been reading up on hauck's sheave work and it sounds like it works miracles. also scored a gytr exhaust brand new for 230 shipped. i have had the wolvie for over a year and figured as much as i like it might as well pimp it out a little.
dannytas
Sep 26, 2017 06:31 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
raman8tor
Sep 20, 2015 07:35 AM
