Superwinch Keeps Smoking Solenoids
Old Sep 15, 2008 | 10:25 AM
BEER SEASON's Avatar
Default Superwinch Keeps Smoking Solenoids
Howdy yall,
I have a 2500lb superwinch that seems to puking out solenoids. It's on my old ladies wolverine 450. It has only been used maybe 20 times tops and does not see what I would call extreme riding conditions - deep water or mud ect. I have triple checked to make sure it's wired right; which it has been all along. The winch always works great if you jumper it or the solenoid is actully working. It's already been through 2 solenoids now and I'm just wondering if I should just by a Warn winch for it. I guess this kinda serves me right for buying made in China junk, but I thought it would last for the minimal use it sees. Anyone think there might be another issue(s) at hand here?
Thx,
Beer Season
Old Sep 15, 2008 | 10:38 AM
Raptor450's Avatar
Make sure the wire from the battery is large enough, make sure all the connections and crimp fittings are tight. Also if you have a ground wire, that needs to be sized correctly and a good ground is needed. If all that is good, you may need a heavier duty solenoid that will handle more amp draw.
Old Sep 15, 2008 | 03:27 PM
hotblooded's Avatar
Raptor450 you are right, if this thing isn't getting good enough current it will smoke it. I had a simiar problem and actually double wired it.
Old Sep 15, 2008 | 04:38 PM
Thankx guys,
I will try going to a heavier wire. Any guage recommedations? Do I need to do it from just from the battery to the solenoid or would it be better to run all the way to the winch itself?
Old Sep 15, 2008 | 04:40 PM
Raptor450's Avatar
All the way to the winch. Not real familiar with ATV winches but I would think it needs at least 10 gauge and not over 4 gauge. I would probably run the same as the wire going to the starter, which is probably 8 gauge. The finer stranded wire will work better than the thick stranded or solid wire.
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
EIF
Apr 20, 2017 07:15 PM
Jackg17
Sep 26, 2015 09:30 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
