Tick, clanging, then nothing
Old Sep 23, 2008 | 09:04 PM
1989250moto4's Avatar
Default Tick, clanging, then nothing
i have a 86 225 moto4. I was driving it and it started ticking/clanging really loud all of a sudden, so i turned around and started driving home. it was working almost prefect for a while then all of a sudden i lost power big time. i was in 5th and had to shift down to 4th and it just keep bogging down. i shut it off and towed it home. i tryed starting it again it seemed to be seized solid i could pick the bike of the ground with the pull cord. i got my socket and got it to turn backwards and now it seems to be turning over fine. What do you think the problem is? my guess is something with valves.
Old Sep 24, 2008 | 08:13 PM
stageIVbanshee's Avatar
sounds like that. just pull the cover off and check them. some times if it gets real hot than it will get stuck. it most likely would be the exhuast valve
sounds like that just pull the cover off and check them. some times if it gets real hot than it will get stuck. it most likely would be the exhuast valve
Old Sep 24, 2008 | 08:15 PM
oops double post,but it could also be your cam chain too check that while your at it.
Old Sep 24, 2008 | 09:06 PM
i checked the camchain and timing today and its all good, i can't get the cam sprocket of to get the camchain out of the way to get the head off
Tomtom86
Aug 7, 2024 07:40 PM
Big bousse
Sep 26, 2015 10:42 AM
MNatv89
Jul 7, 2015 11:36 AM
94DGblaster
Apr 27, 2001 09:51 PM
RotGutBottom
Apr 13, 2001 12:07 AM
