Checking Big Bear Valves Hot or Cold?
Old Oct 2, 2008 | 10:56 AM
Jeepsterbrad's Avatar
Default Checking Big Bear Valves Hot or Cold?
I know the clearance on the valves for my Big Bear but i was told that some bikes need to be checked while the engine is cold and others while its hot. Well i checked it cold and they still seemed tight at TDC. But when i go to run it after it gets hot it has a tap again. Any suggestions?
Old Oct 3, 2008 | 12:31 AM
Doctorturbo's Avatar
GOT BOOST!
All valve specs I know of are set hot unless they have two specs. (Hot and cold)
Here is a little tip for you.
"If" your quad has hot specs and you don't like working on a hot engine (like me) then you can get the engine hot and set the valves to specs. Let the engine cool and check the specs again. Write down this figure somewhere safe. Now you can check the valves cold and get it to factory specs.
Old Oct 3, 2008 | 10:06 AM
thanks for the info, thats a great idea
Ean
Dec 19, 2022 08:48 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
