moto 4 200
Old Oct 5, 2008 | 08:21 PM
hellya5029's Avatar
Default moto 4 200
i have an 87 moto4 200. i am not getting gas to the motor. if you put gas on the spark plug it starts fine then shuts off.
any help??
Old Oct 7, 2008 | 10:29 PM
hellya5029's Avatar
Default moto 4 200
please help
Old Oct 7, 2008 | 11:47 PM
eggenz7's Avatar
Default moto 4 200
check your float. sounds like its stuck shut or there is carmalized gas in there clogging up the carb. try giving the carb a thorough cleaning
Old Oct 8, 2008 | 07:05 AM
cadillacdude1975's Avatar
Default moto 4 200
have you pulled the fuel line off the carb to see if the fuel is flowing out of the tank? that is the most simple way to check and rule out a blockage in the tank and shutoff valve. if it flows to the carb fine, then i agree with the above post with the float not operating correctly.
Old Oct 10, 2008 | 06:12 PM
hellya5029's Avatar
Default moto 4 200
gas is flowing from the tank and the floats are not stuck. carmalized gas?
Old Oct 10, 2008 | 09:52 PM
Default moto 4 200
in other words, how old is the fuel in that tank?
Old Oct 10, 2008 | 10:08 PM
hellya5029's Avatar
Default moto 4 200
end of july
Old Oct 11, 2008 | 09:29 AM
mdj104's Avatar
Default moto 4 200
somthing in the carb is stuck or clogged.give it a good cleaning and see what happens.
Old Oct 11, 2008 | 12:09 PM
TLC's Avatar
TLC
Default moto 4 200
Clean the carb its easy follow these steps http://www.ripperd.com/ftp/admins/carb_rebuild/ If pilot jet is such just use the wire without removing it.
<div class="FTQUOTE"><begin quote>POLARIS--if it ant broke,it will be!! </end quote></div>
LOL Thats a good one.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 11, 2008 | 02:24 PM
hellya5029's Avatar
Default moto 4 200
that link just took me to compare new atv's. i drained the gas out of the tank and carb. put new gas in and it started up first pull. ran for about 5 minutes and died. seemed like it was not getting gas. clogged jets?
