pipes & chain for warrior
Old Oct 15, 2008 | 06:30 PM
ajones's Avatar
Default pipes & chain for warrior
i was just wondering what is the best pipe for a stock 04 warrior. And is it even worth it to get the full kit or is it that big of a difference just to get a slip on. i also need to get a new chain what is the best brandfor the full kit and do i go up teeth to get more speed. thanks for the help
Old Oct 15, 2008 | 10:35 PM
Raptor450's Avatar
HMF slip-on is the way to go on the Warrior. Full pipe is a waste of money on the Warrior only. gopartsdirect.com is where I think I found the cheapest HMF slip-on's - $220 at that time. O-ring chain is the way to go, I usually run D.I.D. just because that's what my local dealers sell. To get more top speed you would need a larger front sprocket or a smaller rear sprocket, but I would recommend keeping the stock gearing for a stock engine. After a few mods, I always kept the stock rear sprocket and went up 1 tooth in the front on mine and it worked great.
Old Oct 15, 2008 | 11:48 PM
MSoule772's Avatar
yea im pretty satisfyed with my HMF on my warrior it peforms a lot better its a good pipe for the money
Old Oct 16, 2008 | 05:07 PM
ajones's Avatar
one more question i was told if i am going to get a new chain they recomend that i get new sprokets, rollers and guides what do you think
Old Oct 16, 2008 | 07:03 PM
Raptor450's Avatar
If your sprockets are worn out, yeah. If your sprockets are worn out and you put on a new chain it could wear your chain out prematurely. Same with your rollers and guide, if they are worn out replace them, if not it will be OK to keep them.
Old Oct 16, 2008 | 07:54 PM
ajones's Avatar
ok well thank you for all you help
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
Bernhard
Sep 25, 2015 12:45 PM
bvolks
Sep 13, 2015 12:57 PM
