Help with Jetting a Warrior 350
Old Nov 2, 2008 | 10:31 PM
Funeral Home guy's Avatar
Default Help with Jetting a Warrior 350
I had to put in a new piston on my warrior. I had it bored out for the new piston. I am wondering if i need to rejet the carb. I took it trail riding today and by the end of the trail the motor was really hot and quit. I let it sit and cool for about a hour and it fired right back up and is fine. A friend told me that it may be running lean because of the bigger piston and that i may need to rejet could this be my problem?
Thanks
Doug
P.S. you can also reply to my email at douglas.glasscock@gmail.com
Old Nov 2, 2008 | 11:10 PM
cherokee99's Avatar
if it overheated then you probly are running a bit lean. i would try rejetting the carb to the next size larger main jet. and possibly adjust the pilot jet 1/4 to 1/2 turns out. that will probably solve the problem.
good luck
Old Nov 2, 2008 | 11:19 PM
Thanks alot for your quick reply. My friend told me the same thing i just wanted to get some more advice. Thanks again for your quick reply.
Old Nov 2, 2008 | 11:31 PM
cherokee99's Avatar
its no prob, thats what the forum is here 4
keep us informed if you have any problems
ReconBayou
Oct 31, 2022 05:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
