Where is idle fuel Screw on 2002 Bear Tracker
Old Nov 21, 2008 | 03:45 PM
FlipFlop425's Avatar
Default Where is idle fuel Screw on 2002 Bear Tracker
Where is it and how many turn out is it supposed to be?
thanks
Old Nov 21, 2008 | 07:41 PM
91Warrior357's Avatar
it should be on the bottom side of the carburetor and the idle screw should be set at to where it has a nice idle not too low to where it wants to cut out and not too high, the fuel screw usally is good at about 2 1/2 turns out or so
Old Nov 22, 2008 | 12:44 PM
I guess I am going to have to take the carb off because I cannot get the 4 screws out that hold the cover on then put it back on and adjust it that way.
Does anyone have a picture of what screw it is?
Old Nov 22, 2008 | 01:06 PM
TLC's Avatar
TLC
02 Beartracker Carb
Its part #24 it a not a crew but has a **** so it can be turned by hand. You just set the idle by ear until it sounds right to you.
Old Nov 22, 2008 | 01:26 PM
thats the idle screw though. I need the fuel mixture screw. I brought the quad from the mountains down and i cannot get it to idle right.
Old Nov 23, 2008 | 10:11 AM
Anyone??????
coolguy420
Jul 10, 2015 01:17 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
MNatv89
Jul 7, 2015 11:36 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
