What does reaming spindles mean
Old Feb 4, 2001 | 12:31 PM
raptorfast's Avatar
I have ordered +1+3 Lonestar A-Arms and they say the spindle needs reaming. What do they mean and can I do it myself and what tools do I need, how long does it take? Whats the procedure.
Sorry just a few ?'s
THanks fellas
Old Feb 5, 2001 | 09:23 AM
sAyIt_fmf's Avatar
It means that the ball joints that will be on your new arms will not fit into the stock spindles.
If the arm kit comes with a tapered reamer...you can just hook it up to a drill and make the holes slightly larger according to the instructions.
My lsr arms came with the reamer...sometimes it is extra.
Old Feb 5, 2001 | 02:35 PM
dstevens's Avatar
i had to ream mine,i got the correct reamer from snap-on part no.r121 $40 you can do it your self,or send them out and pay lonestar,i think
Old Feb 8, 2001 | 10:10 PM
raptorfast's Avatar
Thanks for the insight...I now hoave the part from snap on that you sugest can you tell me how I ream the spindles??? Sorry I have never done this before?? I have everything in hand to do the job I am just unsure how to ream the spindles??
Please,Please tell me how to do do this,,, thanks BJ Carter.
You folks are the best.
Old Feb 8, 2001 | 11:40 PM
dstevens's Avatar
take out the old ball joints , then just get your reamer and start on the outside , twisting and pushing the reamer , keep checking to see if your ball joints will fit, don't ream to far cause the taper is what holds the ball joints tight,just enough room to allow most of the tapered shaft to slip in to the hole, then use the nut and washer to tighten and seat up the shaft, you should be able to tighten up the nut real tight,and then be able to loosen the nut while the shaft stays in place,just ream it with hardley no room at all,after you are able to wiggle the threaded part thru this should be enough
Old Feb 9, 2001 | 09:58 AM
sAyIt_fmf's Avatar
dstevens hit it right about on the head. It seems harder than it is. Just take your time and keep checking to see if the new arm fits.
To be safe...do the job by hand (with out a drill or press) The reamer probably has a hole in the top for the included bar that come with it.
Apply pressure and twist. A bit of wd40 or metal cutting oil will make the job less painful.
Just to make things easier... Once you get one side all lined up and fit properly. Put the reamer back in the hole and wrap a piece of tape around it even with the hole. Then you will know how far to go with the other side.
good luck.
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
metal249
Jul 28, 2015 09:35 AM
scottd
May 13, 2001 07:40 PM
