rejetted raptor WOWWWWW!!!
Old 02-13-2001 | 02:34 PM
ERICsRAPTOR's Avatar
dseater,
Xtreme165 is pointing me your way. I have a BG full exhaust with proflow lid on and ign. advance running 165/170 mains and it just doesn't like the higher rpms AT ALL!. It coughs and cuts out big time. The plug was real white and would cut out alot more with the lid off but with the lid on it isn't as bad(plug color and coughing) but it still had no power in the upper rpms and seems to be running lean. I know very little about jetting --I just ride. It was running good with the slip-on, pro-flow,ign advance @ 150/155. I put the headerpipe on and rejetted it to 160/165 and it started that coughing $hit, I then tried to rejet to 165/170 and it was still not running good at all. The lower RPMs seem to be OK. The upper RPMs have no power and keep coughing and cutting out. Hook a brother up!!!
Old 02-13-2001 | 06:56 PM
ccarpe1's Avatar
What is the factory jetting settings. I am about to start this painful process myself. I've got just the WB E-series slipon to put on.
Old 02-13-2001 | 07:22 PM
redrocker's Avatar
140,145 mains
22.5 pilots
Old 02-14-2001 | 12:14 AM
cjudd's Avatar
Someone should come out with a 2into 1 kit to convert into using one big carb
  #15
Old 02-14-2001 | 01:01 PM
I feel you pain, I feel you pain.
  #16
Old 02-14-2001 | 02:10 PM
NakedRaygun's Avatar
Do you want one big carburetor for simplicity or for performance?
bmxatv10
10-14-2022 07:23 PM
XxS0ccerstarxX
09-24-2015 03:02 PM
black_thunder
09-22-2015 08:59 PM
XxS0ccerstarxX
09-22-2015 03:40 PM
Alex Rodak
09-12-2015 10:39 AM
Quick Reply: rejetted raptor WOWWWWW!!!
