2008 Big Pile of junk I mean Bear
Old Dec 26, 2008 | 03:50 PM
  #21
tripleR's Avatar
Default 2008 Big Pile of junk I mean Bear
I have run K&N filters without any problems and only had to rejet when used in conjunction with aftermarket exhaust.
Old Dec 29, 2008 | 07:37 PM
  #22
mudwiser01's Avatar
I have a 00 recon and 04 recon with k&n filter on both ran year round with no trouble I do understand emissions have become stricter but I dont see why it would not still Idle. Neighbor across the street just bought a 450 grizzly same carb he has k&n filter on his seems to run fine in 60 degree or 25 degree weather
Problem I see with them wanting to jet the carb and I still run a stock exhuast when its 80 degrees and riding am I going to burn up the stock exhaust because its getting just that much more fuel. Or case in point when the put the motor back together they have the timing way off and dont want to own up to their mistake
Old Dec 31, 2008 | 11:49 PM
  #23
mudwiser01's Avatar
Close of this chapter. Dealer called today said Big Bear was ready to pick up they jet both ports. Running good with factory air cleaner, temp is 24 degress runs strong than before. Advised I put k&n back in, in the spring or bring back over and they will reject for summer setting. Called yamaha c.s to ask about what had been done they dont warranty jetting of their carbs,voids warranty if problem brought on by jetting. Here's the confusing part Yamaha admits with clean air restriction at anything under 30 degrees problem may exist, yet they dont support rejetting to make their machines run good. So I am happy B.B runs good starts and idles still have 9 months of warranty left hope I dont have to use any more of it
Old Apr 29, 2009 | 09:26 PM
  #24
cadillacdude1975's Avatar
seems to me this is a dealer issue, not the manufacturer. i would take my money elsewhere next time.
Old Apr 30, 2009 | 07:53 AM
  #25
semi's Avatar
This could be an issue with the dealer too. I Have had good luck with yamaha in the past covering things. Some times the dealer will tell you they called yamaha but they don't. They would have to admit they made an error if it was their fault.
Old May 2, 2009 | 09:35 PM
  #26
cody700's Avatar
This is a dealer issue and I had the same problem with a dealership and went to Yamaha for the problem to be resolved. They took excellent care of me and the problem and I have complete faith in their product, and their willingness to stand behind it.
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
35dodge
Sep 29, 2015 09:40 AM
jbrewster94
Sep 23, 2015 04:16 PM
rgjackson
Sep 23, 2015 01:53 PM
