2005 Grizzly backfires and stalls
Old Dec 23, 2008 | 09:00 AM
sonofthor's Avatar
Default 2005 Grizzly backfires and stalls
I am new to ATVs. I have a 2005 Grizzly that will not stay started. As soon as i release the throttle it stalls. If i keep the throttle on, it backfires. Can someone give me an idea of what might be the problem? Is it bad gas?
Old Dec 23, 2008 | 06:22 PM
muddyweekends's Avatar
my grizzly did the same thing 01. i took the carb. off and cleaned it, mine was popping back so hard that it would blow the rubber boot off where it goes into the intake.
i had a problem with my choke also sticking, i had to take off the black rubber o-ring so the piston would slide back,when i turned off choke. it seems to be fine now.
Old Dec 23, 2008 | 08:24 PM
shpd614's Avatar
Sounds like some plugged jets. A good carb cleaning a fresh fuel would be a good start.
Good Luck!
Old Dec 23, 2008 | 09:36 PM
cherokee99's Avatar
if that dose not work, you may want to bump up your idol, and skrew your pilot jet in a bit. but soundls like classic bad-gas
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
