Need help with yamaha moto 4 80
Old Jan 4, 2009 | 09:04 PM
dasledhed's Avatar
Default Need help with yamaha moto 4 80
Hello,i just bought my son a 1988 yamaha moto 4 80cc.I was wondering if anyone knew if the vent line from the gas cap gets hooked to the carb? I have a hose that comes off the left side of the carb and i dont know where it goes.Im thinking its a vent hose?When i hook it up to the gas cap it runs for awhile then stalls.It wont start again unless i disconnect the hose from the gas cap.I think the vent in the cap itself might be bad.
Old Jan 4, 2009 | 09:25 PM
cherokee99's Avatar
ok....the vent hose comeing out of the gas cap just hangs, or tucks in by the handelbars. it should vent the tank. if it wont start with the cap on then its vapor locking the tank. as for the carb vent hoses idk off hand, but if nothin els keep them tucked someplace so dirt, ect. wont get in. you may be able to poke a hole in the diaphram of the vent cap so it can breath.
Old Jan 4, 2009 | 09:35 PM
dasledhed's Avatar
Ok,thanks.Now i just have to figure out where that hose is suppose to go that comes off the left side of the carb.It may be a vacuum line?
Old Jan 4, 2009 | 09:45 PM
toddmh's Avatar
I'm pretty sure that would be a vacum line
Old Jan 4, 2009 | 09:55 PM
beefy46172's Avatar
Loves To Ride!
Many carbs have vent hoses built on them that connect to nothing. My Warrior carb has a vent hose and a float bowl overflow hose that both just run out of the carb to nothing.
Old Jan 4, 2009 | 09:59 PM
toddmh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: beefy46172
Many carbs have vent hoses built on them that connect to nothing. My Warrior carb has a vent hose and a float bowl overflow hose that both just run out of the carb to nothing.</end quote></div>
My 03 Wolverine had that same hose on the side of the carb,It's just a vent/vacum line..
Old Jan 4, 2009 | 10:11 PM
dasledhed's Avatar
Thanks guys,i'll just zip tie it to the frame up in front of the gas tank.
Old Jan 4, 2009 | 10:15 PM
cherokee99's Avatar
not too tight, so they can breath
wendal
Aug 3, 2024 10:03 PM
Sep 17, 2015 03:06 AM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
