Hotter Spark Plug
Do they make a Hotter Spark Plug for a Warrior. I have a Stock one in it now. I have put a new piston in and had it bored. I also rejetted the main jet from a 145 to a 150. Was told i needed a hotter plug. Any Help
After the new piston. Right when i first start it when it has sat a day or 2 get a little smoke on the choke. Soon as the choke is off no more smoke, But i do have a smell of Buring Gas. I was told that because of the bigger jet in the carb it might be putting to much gas for the standard plug to burn off
Correct me if I'm wrong but the coil only puts out so much. We run 3 different plugs BR8ES,BR9ES, and BR10ES. Yes the 8 is hotter but all it means is there is less ceramic around electrode to disapate the heat so they call it a hotter plug. It isn't that it has more intense spark. I would agree to check the jetting to make sure it's on.
