parking brake
Old Feb 7, 2001 | 08:43 PM
Warrior1369's Avatar
What all do I have to do to take off the parking brake,cables and all?
Old Feb 8, 2001 | 05:12 AM
AdrenalinFreak's Avatar
1. Undo the cable at both ends
2. Grab cable with both hands
3. PULL
4. Throw cable in back of garage somewheres!
Hehe.. Its about that easy.. You should then take your brake lever off of your clutch, or purchase an aftermarket clutch perch. You will have to put the tension adjuster bolt back in (located on the rear caliper) or dirt will ruin your back brake. Nac's racing makes a block off plate which looks nicer. You will also need to unplug the wire coming out of the park-brake lever, it is located somewhere near the front of your bike or under the gas tank.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ahtatu
Sep 28, 2015 12:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
