Electrical issue, 04 Wolverine
Old Jan 17, 2009 | 07:03 PM
Deepriggin's Avatar
Default Electrical issue, 04 Wolverine
Ok, this one has me stumped. Its a 2004 Wolverine 350, new battery. I'll try to use the electrical start, the starter relay will click, but the motor doesnt turn over. put a trickle charger on, it indicates the battery is charged until I go to start it, when it indicates its charging. So, I removed the starter relay and used my pull start. The machine starts up right away, but the lights flicker with the engine rpm. If I try to use the winch to power out they dim, if I try to power in everything electrical wants to shut off, including the engine. Looking back now I'm thinking I shouldve left the relay on for trouble shooting purposes, in case the bike was trying to send a charge to the battery.... Anyways, does anyone have an idea or faced a similar situation? Is it my relay (which will cost $60 from the dealer and CANNOT be returned), or something more major like the stator, magneto, etc...? Thanks in advance!
Old Jan 18, 2009 | 09:30 AM
Dune Rat 2008's Avatar
There are fuses in the relay that maybe bad and if they are it will just click and not turn over so i would check the fuse before you do anything else
Old Jan 18, 2009 | 09:59 AM
Deepriggin's Avatar
Only fuse I saw was mounted just behind the battery, it was ok. Are you saying there's a fuse inside of the starter relay? It appeared to be a sealed unit.... I'll have a better look in couple weeks when I get home from work.
skinnyr6
Aug 25, 2023 02:18 AM
DeFox500
Jul 26, 2015 06:32 PM
Bratman2
Jul 23, 2015 12:36 PM
Unzzy66
Jul 11, 2015 10:01 PM
