Breeze Mods?????
there aint much but most companies make a universal performance pipe/silencer....after that get 18 inch tires fo better raise the gearing a little and im pretty sure u can get any quad bored out!!!for shocks just experiment....breezes are koool
#15
Well if you mean the rejetting take it to a dealer or have your dad help. Take off the carb and look at the tiny number on the mainjet. Go buy the next 2 sizes up. Start with the new bigger number. Ride it and if it backfires or skips letting off at full throttle go one down.If it doesn't go higher until it does then back off. After you find the mainjet you can fine tune it with the clip. The bracketry part would be easy. Go to Ace hardware and buy some 1 and 2inch pieces with holes in each end. The uni vents can be ordered out of www.denniskirk.com . Just drill a hole in your airbox and slip these in. I would forget about making your own pipe/muffler combination now that you know dg makes a pipe for it.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
