2005 yfz
Old Feb 7, 2009 | 01:58 PM
bprfwarrior's Avatar
Default 2005 yfz
ya its got the silencer out but i think its pretty loud.and being only 14 gotta save a while to get a pipe and all that stuff.
Old Feb 24, 2009 | 10:09 PM
sluckman's Avatar
Default 2005 yfz
Here's a free cam mod that will improve top end performance! It's a little technical, but is worth it and it's not too hard(link is below). You will need a torque wrench and a 15 mm hex head socket. While you have the valve cover is off, it would be a good time to check the Valve lash clearance. Have you changed your oil and cleaned your air filter? I am coming off a engine rebuild that cost about $1400, and I did all the labor except for splitting the case and installing the new crank. Even if you use $8 synthetic oil, every 3rd or fourth tank of gas, it is CHEAP insurance compared to rebuilding your engine! Remember your YFZ IS a racing quad, and it's engine is engineered to have high performance, so YOU MUST maintain it as such!
http://www.yfzcentral.com/cammod.htm
Good Luck!!
Scott
salixair
Nov 3, 2015 08:25 AM
01ssls1
Sep 22, 2015 06:50 AM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
