Fuel Leak
Old Feb 4, 2009 | 06:48 PM
motorman1's Avatar
Default Fuel Leak
I have an 2003 350 warrior it is leaking fuel from the bottom of the carb. It is coming out of a tube that looks as if it should have a hose on it. Is the float stuck or should I pull the carb and clean it. Iv'e only owned for short time
Old Feb 5, 2009 | 10:08 AM
02magnum500's Avatar
Gets his share of deer.
Default Fuel Leak
You could have a bad needle and seat in the carb. Or the float is improperly adjusted.
Old Feb 6, 2009 | 11:48 AM
motorman1's Avatar
Default Fuel Leak
Thanks I'm going to look at it this weekend
Old Feb 17, 2009 | 01:59 PM
maddog56's Avatar
Default Fuel Leak
As was mentioned check the seats and I'd also check the floats while you're in there.
randymack
Aug 24, 2015 05:47 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Unzzy66
Jul 11, 2015 10:01 PM
