03 blaster clutch problem HELP!!
Old Feb 8, 2009 | 02:52 PM
thinman's Avatar
Default 03 blaster clutch problem HELP!!
03 blaster clutch quit working. Thought cable broke and replaced it. Slill does not work. Can see the cable pulling lever on shifter side but will not shift. No tension on the handle that says it is engaging the clutch!! Something break inside and how do I pull apart to look??
Old Feb 8, 2009 | 09:26 PM
Blaster6678's Avatar
Usually that happens when you ride it without oil. If it is broken you need to open the whole crank case to fix it.
Old Feb 9, 2009 | 07:11 AM
thinman's Avatar
has plenty of oil in it. never ran it out or ran without it. Take apart from the foot brake side?
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
honda71
Jul 12, 2015 05:56 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
