Warrior not starting
Old Mar 10, 2009 | 06:26 PM
yfs2020's Avatar
Default Warrior not starting
well I got the solenoid but still nothing does anyone have any more ideas I'm about out of them
Old Mar 10, 2009 | 07:22 PM
beefy46172's Avatar
Loves To Ride!
So let me check...you can jump the solenoid and it starts?
Old Mar 10, 2009 | 08:30 PM
yfs2020's Avatar
yep can jump the solenoid
Old Mar 10, 2009 | 08:36 PM
yfs2020's Avatar
new parts (solenoid, key switch, neutral relay, cut off relay, fuse and fuse holder, starter, battery)
I can jump the solenoid and it will start. Checked the continuity on the run switch and it seems fine.
Driving lights work at the switch and my neutral light works fine.
I just don't get it!!! Please HELP...............
Old Mar 10, 2009 | 10:01 PM
  #15
91Warrior357's Avatar
damn this is one of those little simple but anoying problems lol, how exactly are you jumping the solenoid? are the wires in good condition? there not frayed and grounding out of the frame or anything?
Old Mar 10, 2009 | 11:00 PM
  #16
beefy46172's Avatar
Loves To Ride!
That sure sounds like the solenoid could be the only problem still...do you know anyone who could try the solenoid on a different bike to be sure it is working?
Old Mar 10, 2009 | 11:41 PM
  #17
free2blaze's Avatar
what about the push button itself, or the wires in the push button, sounds like a possible broken wire or bad push button, you have already eliminated the starter and solenoid, do you have a manual with wireing diagrams?
Old Mar 11, 2009 | 11:39 AM
  #18
beefy46172's Avatar
Loves To Ride!
I asked him earlier about the button and such and he said it was all fine, but I am thinking that must still be where the problem is as well now.
Old Mar 11, 2009 | 02:51 PM
  #19
yfs2020's Avatar
I just jumped the solenoid with a screwdriver. Don't know if thats a good way to do it but it works. The start button seems fine for continuity. None of the wires look frayed or fried. I think tonight I'm going to just take all the wiring back off the atv and clean and search. Thanks for all the help so far.
Old Mar 12, 2009 | 12:32 AM
  #20
beefy46172's Avatar
Loves To Ride!
Check continuity from the start button to the solenoid wire when the button is pressed in.
