2003 Grizzly
Old Feb 24, 2009 | 10:10 PM
Jkjodzio's Avatar
Default 2003 Grizzly
anyone got any idea what a diode is?? will that cause it not to get spark??? im not getting spark checked all fuse swaped coil of running bike. swapped computer etc.... i have a bad starter relay but i can jump it with a screw drive will it still have spark with jumping it with screwdriver?????????????
Old Feb 25, 2009 | 09:14 AM
ATV_MAN's Avatar
Diode is basically an electrical check valve, only lets current flow one way, there are many types. This should not cause a no spark condition. Have you changed or checked the coil? a starter relay has nothing to do with the spark. Make sure the shut-off switch is in the crank position, you wouldn't believe how many people still try to start in the off position.
Old Feb 25, 2009 | 06:45 PM
Jkjodzio's Avatar
HEY THANKS FOR THE REPLY I TRIED EVERYTHING... I GOT HOME TODAY WITH FRESH MIND AND WENT THROUGH THE SERVICE MANUEL, AND FOUND THAT IT IS THE DIODE IT WILL CAUSE A NO SPARK CONDITION...MAYBE WE CAN ALL LEARN FROM THIS..INSTALLED NEW DIODE AND GOT SPARK!!!
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
cboler9
Sep 24, 2015 08:35 PM
greg86hd
Sep 16, 2015 12:32 AM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
