Yamaha Warrior Wont start
Old Mar 5, 2009 | 08:43 PM
91Warrior357's Avatar
Default Yamaha Warrior Wont start
to check the valves you dont gotta pull the motor of lol, just two little covers to the valves and pull the plug out of the side cover to see your TDC markings and pull the cam cover off.
Old Mar 5, 2009 | 11:01 PM
iam2pro4u's Avatar
Well i was gonna check the rings and all also. Thats why i said pull the motor. Just so everything was easy to get to.
Old Mar 6, 2009 | 07:29 AM
JLsparky7's Avatar
Heres a list of stuff you might want to try.....
New plug (might not be a strong spark)
Fresh gas
You said it has good compression. Is that by a gauge or you guessing?
Idle fuel mixture screw should be 2 turns out
Clean your carb again and double check your idle jet
Clean your choke real well too
Hope this helps.
Old Mar 6, 2009 | 01:42 PM
beefy46172's Avatar
Loves To Ride!
<div class="FTQUOTE"><begin quote>Originally posted by: iam2pro4u
Fuel petcock is working theres fuel flowing. yes the switch was on lol. I didn't check the valve clearance. .</end quote></div>
Just have to check, it does come up around here from time to time, lol.
Anyhow, take that new carb apart and be sure all the jets are clean and that the choke and air/fuel mixture screw are both working properly. If that a/f screw has been tightened too much this could happen. I would also check the timing as previously mentioned, could have a loose timing chain and have jumped a few teeth.
Old Mar 6, 2009 | 01:46 PM
  #15
iam2pro4u's Avatar
Ok well what is the factory adjustment for the a/f screw?
Old Mar 6, 2009 | 02:16 PM
  #16
Swerve's Avatar
1 1/4 turns out, according to the service manual.
Old Mar 6, 2009 | 04:53 PM
  #17
iam2pro4u's Avatar
Thanks ima make sure that its adjusted right.
Old Mar 7, 2009 | 11:18 PM
  #18
iam2pro4u's Avatar
I checked the mixture screw on the carb and it was adjusted right. And it still doesnt start. i was wondering if neone knows how much voltage should be going to the cdi and all.
Old Mar 9, 2009 | 12:13 AM
  #19
iam2pro4u's Avatar
Anyone?
Old Mar 9, 2009 | 10:18 AM
  #20
redneckrider9's Avatar
if your getting spark its not the cdi box ,you wouldnt get any spark,if you checked every thing else it could have jumped time ,or it could be in the carb like everyone else said
