Grizz 660 Rear brake light?
Old Mar 15, 2009 | 03:59 PM
Jbridered's Avatar
Default Grizz 660 Rear brake light?
Whenever i turn my key on my rear brake light comes on and will not turn off unless the key is off. Anyone know why are how to fix? Thanks
Old Mar 27, 2009 | 10:25 AM
grizz man's Avatar
the problem is in the brake switch which is on the right front side of the atv if you were sitting on it forward. its down by the foot brake tucked behind some plastic. You can either try adjusting it or just replace it. I just replaced mine. Easy fix.
Old Mar 27, 2009 | 05:37 PM
Jbridered's Avatar
Thanks i will check it out.
Old Mar 29, 2009 | 03:15 PM
grizz man's Avatar
how did you make out on that rear brake light. that switch cure your problem?
Old Mar 29, 2009 | 04:27 PM
Jbridered's Avatar
Yeah its fixed. I unplugged the wire from the connection and then backed it off some. It was screwed in too far. Thanks
greg74
Sep 10, 2019 03:03 PM
Sandman2.0
Jul 21, 2015 09:03 AM
toonces
Jul 16, 2015 03:19 PM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
