Weird Warrior Problems
Old Mar 21, 2009 | 05:45 PM
Yam_Blaster's Avatar
Default Weird Warrior Problems
ok, i just got finished checking the rectifier and found out that the red wire is cut and taped..where does this wire lead to?
Old Mar 21, 2009 | 06:50 PM
jaytau's Avatar
It's the wire that feeds power to any thing that needs power while running, like the battery.
Old Mar 21, 2009 | 07:15 PM
do you know where it connects to from the rectifier?
Old Mar 22, 2009 | 01:23 AM
91Warrior357's Avatar
mm off he top of my head im not sure, somewhere in the wiring harness you should be able to find where it would plug in, what kinda wire is it? 3 prong 4 prong or is it like a male and female type connector(shaped like a pill and plug into eachother)
Old Mar 22, 2009 | 06:50 PM
  #15
yea it one of those plug connectors, its grey...it has one black wire, three white wires and the red wire that is cut about four inches from the connector.
Old Mar 22, 2009 | 09:43 PM
  #16
jaytau's Avatar
Red feeds power to the CDI and battery, brown would feed power to the acc. White wires come from the stator, like an alternator on a car. Rectifier turns the power to DC, there should be a fuse block between the rectifier and the battery connected at the starter soleniod. Hope this helps figure things out.
Old Mar 23, 2009 | 06:06 PM
  #17
so the red wire connects to the fuse before the positive wire is connected to the battery?
red wire== [fuse]== [+ battery -]
or
==[fuse]==red wire==[ + battery -]
hope i didn't do it too confusing.
Old Mar 23, 2009 | 10:49 PM
  #18
jaytau's Avatar
The wire on the warrior here has the fuse block running to the power wire to the soleniod. There a heavy red wire is then connected to the battery. I do believe the fuse block ties in to the harness wire feed by the rectifier.
rectifier--fuse block---battery positive cable. in that order hope that helps you out.
Old Mar 23, 2009 | 11:00 PM
  #19
oh ok, thanks yea that helps...ill see if it works tomorrow, and ill post up what happens
Old Mar 24, 2009 | 05:39 PM
  #20
ok, that might have fixed the part about the battery draining, but now i think the starter coil is broken because the engine wont crank
