warrior help
Old Mar 22, 2009 | 10:23 PM
freshy21's Avatar
Default warrior help
ok i got a warrior its start about and runs great, itll go into reverse and run perfectt. but when i go to shift into forward gears itll make a lound clunk, and bang and no move? any ideas??? its a extremly lound horrible metal on metabl clunking.
Old Mar 23, 2009 | 07:56 AM
JLsparky7's Avatar
Hows the oil?
Is it full?
Have you changed it?
What color was it when you changed it if you did?
Was there metal shavings?
What kind of oil is in it?
Old Mar 23, 2009 | 10:38 AM
Skatike27's Avatar
My buddy had the same thing happen to his warrior. The reverse gear teeth were shot. He took it to a repair shop, they told him that it happened because he would be in a forward gear when he shifted into reverse. Apperently you have to have the wheeler in the neutral position when you shift into reverse. Best of luck.
Old Mar 23, 2009 | 11:26 AM
freshy21's Avatar
oil looks good added a quart stop the engine cling but still wont shift into grear, itll shift in but wont engage.
freshy21's Avatar
wheres this gear at??
Old Mar 23, 2009 | 01:54 PM
Skatike27's Avatar
The gear is located forward of the output shaft inside the case. You will have to split the transmission case to get to it.
Old Mar 23, 2009 | 02:42 PM
Swerve's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Skatike27
My buddy had the same thing happen to his warrior. The reverse gear teeth were shot. He took it to a repair shop, they told him that it happened because he would be in a forward gear when he shifted into reverse. Apperently you have to have the wheeler in the neutral position when you shift into reverse. Best of luck.</end quote></div>
Is there any validity to that? I don't ever put my warrior in nuetral before I shift it into reverse but I have never had any problems.
I would definitly think that something was wrong internally with the transmission, though. Does it make any noise in the transmission when your driving in reverse?
Old Mar 28, 2009 | 12:58 PM
trail hound 97warrior's Avatar
check adjustment of shifter linkage. may not be it but is worth a try and its free.
Old Mar 28, 2009 | 03:22 PM
91Warrior357's Avatar
yea try to adjust the linkage, it might be worth a shot, i know when i use reverse on mine i put it into neutral first to be on safe side
Old Mar 29, 2009 | 12:42 PM
NickWarrior's Avatar
Can somebody tell me what gas and oil mixture a yamaha warrior takes
