Yamaha Blaster leaking gas
Old Mar 29, 2009 | 04:54 PM
nrinen2374's Avatar
Default Yamaha Blaster leaking gas
My 2006 Blaster has recently started leaking gas running or not. before i start taking the carb apart. does anyone think it is something other than the float?
Old Mar 29, 2009 | 05:02 PM
91Warrior357's Avatar
if its coming out of the bowls overflow tube then most likely it is the float sticking or something, prolly just needs cleaned up
Old Mar 29, 2009 | 07:25 PM
JLsparky7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 91Warrior357
if its coming out of the bowls overflow tube then most likely it is the float sticking or something, prolly just needs cleaned up</end quote></div>
Yea, its either a stuck float or a dirty pilot jet.
Old Mar 31, 2009 | 10:08 PM
nrinen2374's Avatar
should I remove the carb? Can clean the float from just removing the float chamber?
Old Mar 31, 2009 | 10:43 PM
JLsparky7's Avatar
Remove the carb and clean the float and idle jet a little better. If you have an air compressor then spray out the choke and idle jet holes.
Old Mar 31, 2009 | 11:34 PM
nrinen2374's Avatar
I have stopped the leak, but now I can not get it to start.
Old Apr 1, 2009 | 11:26 AM
JLsparky7's Avatar
Turn the gas back on.
toonces
Aug 13, 2015 12:40 PM
315blaster
Aug 8, 2015 08:13 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
