Setting the shocks
Old Apr 4, 2009 | 03:52 PM
fireman4's Avatar
Default Setting the shocks
How do i go about making the shocks go to another level. I only weigh about 160lbs and the shocks are very stiff. Do i need a special tool to change the stiffness?
Old Apr 4, 2009 | 07:57 PM
91Warrior357's Avatar
what kind of 4wheeler? i know on most quads theres a big adjuster at the bottom of the shock and u gotta lift your atv off the ground so the shock has no weight on it, then turn the bottom adjuster one way to make it stiffer or the other to make it softer, i cant member which way makes it softer, if u look at it real good you can tell which way you should turn it.
Old Apr 4, 2009 | 09:02 PM
fireman4's Avatar
I have an 03 blaster.
Nosniborpapa
Sep 19, 2015 07:07 PM
Alex G.
Sep 19, 2015 06:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
