backfire
Old Apr 9, 2009 | 07:00 PM
marqu3ll's Avatar
Default backfire
I have a 08 yfz450, I just installed a motoworks sr4 slip on and a jet kit. The quad runs great is fast and idles great. My problem is if I jab the throttle real fast it backfires. If I jab the throttle real fast to full throttle it will die. I have installed a few different jets changed the needle but still the same thing. I have a dynojet jet kit installed so the jets are numbered different than most. Right now I have A 48 pilot, 150main and needle on third groove, air/fuel screw 1.5 turns and airbox lid off. What would cause this too lean, bad plug wouldnt it run bad if it was to lean. I have tried a few different jetting combos and it does the same IM pretty sure it did this before I changed the pipe. I didnt ride it very much with stock jetting and pipe.
Old Apr 10, 2009 | 09:15 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
It will do it even on a properly jetted bike if it's not at running temp. Make sure you not testing this on a cold engine.
Old Apr 10, 2009 | 02:45 PM
marqu3ll's Avatar
I fixed the problem with the zip tie mod
Old Apr 10, 2009 | 08:38 PM
Koopa's Avatar
Hmm. First I've heard of that mod. So from what I read people have problems with bogging down when punching it while riding. I've never had an issue like that.
Glad you got it fixed.
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
