New Carb for warrior?
Old Apr 26, 2009 | 03:59 PM
Mud Junkie's Avatar
These are all good tips, as I just went through this with my warrior. Sounds like your issue is most definately fixable and a new carb is not necessary. Plus, like 91warrior357 said, an aftermarket one is not cheap.
Another good tip - get yourself a Cylmer manual. It has a whole section on the carb with easy instructions and good pics. If your a novice to carbs (like I was) it will be the best $25-30 you will probably spend on the quad.
Old Apr 30, 2009 | 05:40 PM
Toyota Dave's Avatar
I already have a repair manual.
I cleaned the carb the atv seems to start better but it is still leaking gas. The floats had gunk built up on them but i got rid of all that what else could cause it to leak?
I did see where a gasket needs to be replaced and a o ring type thing.
Old May 3, 2009 | 03:11 PM
Originally Posted by scottd
Would you like to be over and done with all your problems? Please check out my remanufactured Warrior carbs on ebay! See auction #200336935343
I can definately help you out.
Anyone else?
Old May 3, 2009 | 03:42 PM
KYDRIVER_1's Avatar
You have made sure the bowl drain screw is tightened down.
  #15
beefy46172's Avatar
Loves To Ride!
What do you mean by gas is leaking? Is it leaking if you leave it overnight or you can see a drip at all times?
I'm gonna reiterate you do not need a new carb so pass on this guy trying to make a quick buck off of you without giving any advice. MAYBE a rebuild kit that comes with new gaskets etc, which you can pick up at your local dealer or online for under $20.
Old May 3, 2009 | 04:14 PM
  #16
Yeah if it sits overnight it still leaks/drips from the bottom tube.
Old May 3, 2009 | 04:45 PM
  #17
beefy46172's Avatar
Loves To Ride!
You should be turning the fuel petcock off when you are not riding. It is fairly common to have a drip or leak if you leave it overnight. Mine will drip some from the bowl overflow if I leave the valve open even.
Old May 5, 2009 | 09:18 PM
  #18
91dime's Avatar
Originally Posted by 91Warrior357
edelbrock makes a pretty nice carb for the warrior but there not cheap around $400, if you have a few mods they respond real well to it otherwise if your bike is near stock you wont get that much of a performance gain to it, just nice throttle response and east starting, ive seen people fit z400 carbs on warriors also, with a raptor350 intake boot it will bolt right up but you have to change a few things, the warriors carbs can be a real pain to tune right.
what else is needed to put a z400 carb on a warrior? I am interested in this, shouldn't be to expensive to do should it?
Old May 5, 2009 | 09:53 PM
  #19
91Warrior357's Avatar
mmm damn im tryin to remember, you need the raptor 350 intake manifold piece in order for the z400 carb to hook up, and i cant remember if you need the raptor 350 throttle cable or a z400 throttle cable, and your warrior carb to airbox boot will have to be stretched, other wise its not gonna be able to reach the airbox, i think people do this by heating it up and slowly stretching it, also it will need to be rejetted, i think theres a sticky on this at yfm350.proboards.com
Old May 5, 2009 | 10:26 PM
  #20
91dime's Avatar
is this a good upgrade in terms on performance? I will do it just because its easier to work on.
