New Carb for warrior?
Old May 6, 2009 | 12:14 AM
  #21
91Warrior357's Avatar
yea it will make a good difference, people either do a z400 carb, edelbrock carb, or a mikuni flatside carb with an accel pump 36-38 mm, the edelbrocks do good but they dont have a choke and that sorta creates a problem if you ride in real cold conditions but there so easy to dial in and have instant throttle response and easier overall starting, but overall mikuni flat side carbs are about the best carb you can use on a warrior imo, warrior stock carbs are just kinda pooey really even if dialed in perfect they still will have a hesitation, the design just has a real weak fuel stream.
Old May 6, 2009 | 12:24 AM
  #22
91dime's Avatar
how much do the mikuni carbs run? Did they put them on any bike stock?
Old May 6, 2009 | 05:46 PM
  #23
Toyota Dave's Avatar
Why does a warrior carb have 2 cables going to it? Of course one is the throtle.
Old May 7, 2009 | 07:14 PM
  #24
anyone?
Old May 7, 2009 | 07:25 PM
  #25
beefy46172's Avatar
Loves To Ride!
Two cables? Never heard of such a thing. Should just have the throttle cable, fuel line, and 2 vent tubes (one out the bottom and the other the top)
Unless its an aftermarket carb with a remote choke mount. (handlebars)
Old May 7, 2009 | 07:42 PM
  #26
Theres a cable going to where the idle screw is on the side you take a little black cover off to get to it. And the one on top wiich is the throttle.
Old May 8, 2009 | 08:38 AM
  #27
KYDRIVER_1's Avatar
The one under the black cover is you throttle cable.
It enters at the top of the carb. Or at least that is how my Mikuni is.
Old May 8, 2009 | 01:17 PM
  #28
the warriors carbs changed a little over the years, the older warriors had two cables one on the top and one on the side goin into black cover, here you can see what im talkin about...top is from an 88 bottom is from a 96
Old May 8, 2009 | 07:27 PM
  #29
KYDRIVER_1's Avatar
I see. Mine is the newer one. When did they change them? When they changed em up in the late 80's?
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Reactant
Jul 16, 2015 10:29 PM
