warrior 1996 no forward gears
Old Apr 26, 2009 | 07:34 PM
ccokeboy's Avatar
Default warrior 1996 no forward gears
i had 350 warrior out today after riding for some time i lost all forward gears also when i put in reverse it works but not as fast as it did before ..oil was just changed last weekend and is clean with no metal i hear no noise and no forward movement at all... what can i check before taking in to yamaha dealer ..could the shift **** for forward and reverse be messed up.. forks clutch... has this happened to anyone else .. thanks for any help
Old Apr 26, 2009 | 08:07 PM
2Owanage's Avatar
Does it make like a hard clicking sound?
Old Apr 26, 2009 | 08:14 PM
ccokeboy's Avatar
no i hear no sound when i clutch and shift ...
Old Apr 26, 2009 | 09:19 PM
91Warrior357's Avatar
sounds like clutches are toast, the reverse is a real short gear which is why it prolly at least moves a little bit, alot of the time when a clutch is going bad it can be ok in the lower gears but once you get up around 4th 5th 6th you can feel it slip, but on such a short gear like reverse it might be the only gear that actually will still let the atv move, i guess its possible the reverse linkage could be way out of adjustment but i doubt it, id pull clutch cover off and take a look at that.
Old Apr 27, 2009 | 05:44 AM
ccokeboy's Avatar
ok i am going to try to pull after work today thanks
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
Ashley S
Jul 31, 2015 09:46 AM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
