05' raptor 350 backfires-any suggestions?
Old 06-07-2009 | 05:32 PM
scox7681's Avatar
Default 05' raptor 350 backfires-any suggestions?
I have an 05' raptor 350 with few hours on it, everything is clean, never been in deep water, but it backfires now, help please!
Old 06-07-2009 | 05:46 PM
91Warrior357's Avatar
when does it backfire? when you let off the gas or when you try to accelerate? and im guessing its all stock? airbox lid isnt removed? reverse sensor and parking break sensor i think can also cause problems if there faulty
Old 06-07-2009 | 06:08 PM
scox7681's Avatar
It backfires the worst at an idle, it lessens during acceleration, but still does it. It's all stock. Will the air box lid being off cause it to backfire?
Old 06-07-2009 | 06:23 PM
yea removing the lid draws in alot more air requiring you to richen it up, which involves using a bigger main jet, adjusting the needle, the fuel screw on it might need adjusting they come kinda lean from the factory, screw it all the way in untill seated then back it off 2 1/2 rotations and see if it cures it if not you can play with it a lil and it might smooth out the idle, it might also need a good carb cleaning.
08-25-2015 11:16 PM
black_thunder
08-19-2015 03:23 AM
brad wheeler
07-13-2015 11:19 PM
Dirtbikemike1
Technical and How-To Articles
10
07-12-2015 07:22 PM
Dirtbikemike1
07-09-2015 01:27 AM
Quick Reply: 05' raptor 350 backfires-any suggestions?
