Warrior Chain tightness
Old Jul 16, 2009 | 04:41 PM
blazeC2's Avatar
Default Warrior Chain tightness
I was just riding my warrior and to me it feels like there is a lot of slack in the chain. there is about 2 inches of play up and down. i don't know much about atv's so i was hoping i could get some feedback as to how tight it should be
Old Jul 16, 2009 | 04:49 PM
o2bfst's Avatar
so your saying theres 2 inches down and 2 inches up?? totaling 4 inches??? if so you need a new chain it has streached alot. if your saying you have 2 inches total play your alset. you can go a little tighter if you want but by the time you sit on it it your weight will tighten it up some also. but if you go to tight it will cause premature wear on the sprockets and chain.
Old Jul 16, 2009 | 05:03 PM
blazeC2's Avatar
there is 2 inches TOTAL play and that is while i am sitting on it.
Old Jul 16, 2009 | 05:07 PM
o2bfst's Avatar
ok then it will be more when your off. there should be 2 total when the quad has no passengers on it. depending on how much the chain has been adjusted already. you may be in need of a new chain. if so it is highly recomended that the chain and sprockets be done as a set.
Old Jul 16, 2009 | 05:24 PM
blazeC2's Avatar
ok thanks for the help. i will add that to my long list of parts
Old Jul 16, 2009 | 05:32 PM
o2bfst's Avatar
hey no problem pal.
Old Jul 17, 2009 | 08:36 PM
91Warrior357's Avatar
if you get a new chain and sprockets its also a good idea to decide whether or not you want a +1 bigger front sprocket for a little more top speed and longer gears or a -1 tooth to make it a little snappier and better in the woods and such. i recommend sunstar and jt sprockets, d.i.d. and rk chains, if your happy with the way your gearing is then just leave it at stock ratio when you replace them.
Old Jul 18, 2009 | 08:52 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
chain should have .5-1" of play when properly adjusted and someone is sitting on it
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
