Blaster jet question
Old Aug 8, 2009 | 11:51 AM
steve 37's Avatar
Default Blaster jet question
I went to the local dealer for some bigger jets and they had none over the #250 size, thats the size I have. the guy told me to drill it out. I got my number drill bit set out and a #54 fits in perfect (no slop). I had it bored out and am wondering what I should drill it out to..? Any help is appreciated
Old Aug 8, 2009 | 06:27 PM
rschaub's Avatar
Default Why ?
Don't drill it out. You cannot keep the drill steady enough to make it a specific size so don't try it. Why are you looking for a larger jet ? If you put a chamber on it maybe but you might want to contact a local aftermarket dealer that will sell you a jet. Only go maybe 1 to 2 sizes bigger on the main. Remember that the main is only involved at wide open throttle. Keep a good eye on the plug ceramic for brownish color..not grey. Look down in the plug where the white ceramic makes contact with the metal housing with the threaded portion of the plug. You should read the plug at the bottom so get out a light and take a look all the way down inside. Good luck and don't blow it up !
Old Aug 9, 2009 | 11:23 AM
steve 37's Avatar
Ok, thanks. This thing leaned out and scored the wall. I had it bored and the owner said to go two sizes bigger and I should be good.
Old Aug 12, 2009 | 07:33 PM
steve 37's Avatar
I got the jet and installed it, but then my needle and slide will not go all the way into the carb body. It goes about 3/4's in then will not go anymore ( guide pin is in line too). Is it needle to hole alignment thats screwing with me or something I am not noticing???
Old Aug 12, 2009 | 07:37 PM
rschaub's Avatar
Default Rotate the slide
You have to rotate the slide 180 degrees so the slot in the slide fits over the pin in the carb. If you look at the slide you will notice at the bottom there is a cut away. That should face to the back and the slide will go right in. Good luck.
Old Aug 12, 2009 | 07:41 PM
rschaub's Avatar
Default It might be the needle too...
The needles are pretty loose in the slide and can sometimes miss the hole or main well tube. You should be able to see that if you look in the carb as you are sliding the slide down into the carb. Use something like needlenose to grab the needle lightly and align it with the hole.. drop it in...good luck.
Old Aug 12, 2009 | 09:56 PM
steve 37's Avatar
Thanks, will check it out.
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
mark23
Oct 1, 2015 09:57 AM
greg86hd
Sep 16, 2015 12:32 AM
nastyblaster100
Sep 13, 2015 01:19 PM
