bruin wont run
Old Aug 14, 2009 | 03:49 PM
KFB 250's Avatar
Default bruin wont run
ive got a yamaha bruin 250 and it wont run. i have tried almost everything. I took apart the carburetor and cleaned it. it was pretty gummed up but i cleaned it. its back together. still wouldnt run. shot some quickstart into the airbox and it starts on that but still wont run. any suggestions?
Old Aug 14, 2009 | 05:50 PM
wheily's Avatar
have you pulled the fuel line and made sure it flows? and checked that there is fuel in the carb
Old Aug 15, 2009 | 03:04 PM
KFB 250's Avatar
yeah i did that. the fuel is flowing fine. even when i took out the carb the gas poured out of it.
Old Aug 15, 2009 | 05:33 PM
wheily's Avatar
what i had to do when i cleaned mine is sprayed carb cleaner threw the the mix jet by pulling the mix screw out and ther was 3or 4 tiny holes by the throttle blades that it came out of i know mine wouldnt run cause only one hole would let fuel threw.. hope this helps
Old Aug 17, 2009 | 11:02 AM
KFB 250's Avatar
ok thanks i cleaned all the holes but i will try that out it might work
Ean
Dec 19, 2022 08:48 AM
blessedn09
Aug 9, 2015 03:07 AM
papahouse
Jul 28, 2015 12:42 PM
roperdog
Mar 15, 2005 11:58 PM
Nicko
Utility ATVs
15
May 29, 2004 12:33 PM
