2002 Grizzly 660 - questions
Old Oct 4, 2009 | 11:13 AM
chrisd0729's Avatar
Default 2002 Grizzly 660 - questions
I'm looking at a 2002 Grizzly 660 later today and have a few questions:
1) Will this be much faster than a stock 02 Warrior 350?
2) is $3500 fair for a decent shape 02 660 with frt/rear winches, full skids and 1700 miles?
3) Outside of the normal stuff to look at on any other used quad, is there anything specific to a Grizz that I need to look at?
Thanks in advance
Old Oct 4, 2009 | 11:25 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
yes
yes
check for binding in the cv axles when turning in 4wd
Old Oct 4, 2009 | 12:50 PM
chrisd0729's Avatar
Originally Posted by Speedy2222
yes
yes
I assume I can check this with tight turns in 4wd and see if the inside of the quad hops?
Old Oct 7, 2009 | 09:20 PM
Andy Bassham's Avatar
I can tell you this, I wouldnt sell you my 02 Grizzly with 2500 miles on it for that much. Condition is everything. A walk around and test ride should tell you a lot about it. Pull off the side panels and take a look at the engine. This isnt an area that gets washed off much and you can also see if there is oil around the head gasket. One good thing about looking at a used quad is if somebody ragged it out, it normally shows.
RedRancher
Oct 15, 2020 01:45 PM
BigT137
3) General Discussions..
Aug 19, 2015 12:09 AM
MNatv89
Aug 10, 2015 02:20 PM
coolguy420
Jul 28, 2015 01:54 AM
200es
Jul 10, 2015 09:09 AM
