raptor not starting
Old Oct 6, 2009 | 07:09 PM
warrior405's Avatar
Default raptor not starting
the past few days i have been having to charge the battery on my raptor 660 so it will crank. the battery is only 6 months old. today i went to crank it and it will just make a click noise and that is it. i tried to jump start it with my pickup turned off and still just a click. i got a volt meter and it shows 12.8 volts. i tried to short the solenoid out and when i did that the solenoid would not even spark or turn over the motor or anything. would could the problem be?
Old Oct 7, 2009 | 07:11 PM
charlijet's Avatar
sounds like the starter itself is bad. put 12 volts to it directly
Old Oct 7, 2009 | 07:37 PM
Doctorturbo's Avatar
GOT BOOST!
Charge the battery overnight and then try it. If it dosen't work then load test the battery. Battery voltage means next to nothing.
Old Oct 7, 2009 | 09:54 PM
warrior405's Avatar
charlijet read my mind. i went and put full 12v on it and didnt work. so luckily i had a spare starter. put it on and cranked over faster than ever!!
Old Oct 9, 2009 | 07:00 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
If you could pull start it (pop the clutch) and it starts I would definetly suspect a starter/silinoid issue
AtvManiac78
Jul 11, 2015 03:20 AM
VascoConroy
Jun 12, 2015 10:30 AM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
