Having bogging problems on 06 yfz 450 with just DR D exhaust system
Old Oct 21, 2009 | 05:42 PM
Halsey77's Avatar
Default Having bogging problems on 06 yfz 450 with just DR D exhaust system
My 2006 yfz 450 is haveing bogging problems in first gear mainly and some what second like when i will just be puttin around it and try to get after it all of a sudden it will start to bog than catch up with its self? whats the issue anyone know
Old Oct 22, 2009 | 08:18 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
I assume you rejetted when you put on the exhaust. It may be getting to much fuel/not enough air. Make sure the filter is clean. May have to reduce the jet size if all else fails.
These 450's like to idle high. I had a bit of a trouble when I had mine idling about the same rpm range i was used to on my other wheelers. I turned it up slightly and was surprised how the little increase changed the way it ran.
And welcome to the forums!
Old Oct 22, 2009 | 01:22 PM
Slater - YFZ 450's Avatar
Default Dr D exhaust and bogging
Mine did the same thing at first. I have an 04 YFZ with the same exhaust system. With the right jetting you should take the air box lid off and still may have to bump up the idle. I also use a K&N. Worked for me.
My exhaust system didn't come with a clamp. It says the system is designed that way. Any thoughts on that?
Old Oct 22, 2009 | 02:11 PM
Koopa's Avatar
Well, depending on jetting the lid can be on or off. Did the pipe come with instructions on jetting? If followed there instructions it's probably specified with or without lid.
Not sure on the clamp. My graydon doesn't have a clamp but, I'm thinking it should. You can see where a slight exhaust leak has formed around the pipe to mid pipe couple.
Old Oct 22, 2009 | 11:26 PM
Halsey77's Avatar
Yeah a kinda think its the fuel pump cause it seems to be a common problem with yfz 450s 06 and up but the clamp does not come because one is not needed and it is jetted clean filter and yeah
Old Oct 23, 2009 | 08:11 AM
Koopa's Avatar
There is a "zip tie" mod that helps with the bog off idle. Haven't known it to affect much going into second.
Old Nov 11, 2009 | 11:24 AM
Natas's Avatar
I have posted a video on YouTube showing you the process of doing the
Zip Tie mod that fixes the bog issue.
Here is the link
YouTube - YFZ450 Zip Tie Mod
if you have any questions message me on YouTube or leave a comment
on the video.
Also if the video was helpfull or you just liked the video please rate it by clicking on the stars.
I hope this helps *
Old Nov 17, 2009 | 02:37 PM
nickmon3's Avatar
try moving the clip up a notch on the needle in the carb
Old Nov 17, 2009 | 06:54 PM
tfunk22008's Avatar
they also make a quick shot add on for the carburetor that makes it go away thats the route i took intead of the zip tie it was more dependable
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jul 5, 2015 09:04 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
