newbie questions for a 1989 warrior
Old 11-13-2009, 09:24 AM
1989warrior's Avatar
i just had it out for a short ride. it has one heck of a wobble at the front end. do these things have wheel bearings up front?
i'm also having a hard time getting the rear brake resevoir cap off. is it just a simple twist off? or is it a push and turn?
Old 11-13-2009, 09:44 AM
beefy46172's Avatar
Loves To Ride!
Yes they have wheel bearings in front, pain in the *** to change too but I bet it needs it. Check all the ball joints also. The reservoir cap should just screw off.
Old 11-13-2009, 09:52 AM
thanks beefy. i'll go up to the shop and order up some new bearings today.
Old 11-14-2009, 06:55 AM
can i pressure wash this thing? its covered in mud and most likely some cow poo since it came from a cattle farm.
is there areas i should avoid? i'm not looking to shine it, i just want to get all the clumps of mudd and what not off of it.
  #15
Old 11-16-2009, 01:42 AM
beefy46172's Avatar
Loves To Ride!
You can pretty well go wild on it as long as the motor is nice and cool. Just avoid excessive spraying of electronics and put a sock in the tailpipe or something...and don't forget to take it out when your done. Also avoid hitting the carb/airbox area with too much consistent pressure.
John Reed
09-09-2015 03:46 AM
that1redhead
09-08-2015 11:47 AM
MooseHenden
09-06-2015 04:24 PM
Logan Collins
09-05-2015 08:03 PM
jeff mc
Dunes and Dune Machines
09-03-2015 07:47 PM
Quick Reply: newbie questions for a 1989 warrior
